1969 Mustang Rear Axle Vent - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2010, 08:07 PM
CandyRed69's Avatar
I noticed that a previous owner put a bolt in the rear axle vent opening on my car. What does the rear axle vent do, and where does the hose coming off the vent go?
Old 04-03-2010, 08:52 PM
big gear head's Avatar
High Performance Rear Ends
The vent lets off pressure that builds up in the rear end when it gets warm. If the vent does not work then the seals and gaskets will start leaking because of the pressure. Many Ford rear end vents also have the brake line built in. There shouldn't be a hose coming off of the vent other than the brake hose.
Old 04-03-2010, 08:57 PM
CandyRed69's Avatar
Thanks! The pictures I've seen in parts catalogs show a hose coming off the vent (about the size of a fuel line hose, it looks like). It looks like it slips over the top of the vent nipple. I have no idea where the other end goes.
Old 04-03-2010, 09:05 PM
You might find something usefull here. There are a few pictures that show the brake hose coming off of the vent. http://www.kevinstang.com/Ninecase.htm
Old 04-03-2010, 09:12 PM
CandyRed69's Avatar
Thanks for the help!!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
'86 Caprice Sedan: 7.5 or 7.625 rear axle voodooracer Transmission - Rearend 29 11-06-2007 06:37 PM
rear axle true or not steve t Transmission - Rearend 3 03-31-2007 08:36 PM
rear axel vent Tbucit Transmission - Rearend 4 11-29-2006 04:28 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 06:23 PM
