1969 T-bird disc brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2003, 06:59 PM
Post 1969 T-bird disc brakes
I have a 1968 galaxie 500 that has drum brakes.
I have access to a wrecked 69 bird. can I use the spindles and disc from this donnor car.
Old 01-27-2003, 07:35 PM
4 Jaw Chuck's Avatar
Post
MMmmmm...my first car, 68 Galaxie. I think the widths are different between the T-Bird and the Galaxie?, double check to make sure. Other wise except for the swapping of parts and fabricating lines and mounting the master cylinder it should be straight forward.
Just to be on the safe side I would check the spindles to make sure they are the same.
Outlawed tunes from outlawed pipes
