1970 Buick Electra 455, Tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2011, 08:13 PM
BZLY904's Avatar
Hi guys i'm new to this forum. I have a few question about a swap out. At the moment i have an 1970 Buick Electra 455 with three speed transmission.Someone recommended me to use the 200r,then i was told i could use the 700 r. Now this is a transmission forum, i think this would give me the best knowledge i need. Thanks
Old 09-17-2011, 08:50 PM
WDCreech's Avatar
Grumpy Old Goat Herder
With a 700, you would have to use a Chevy/BOP (Buick-Olds-Pontiac) bellhousing adapter. The 200 came with either Chevy or BOP patterns.
Old 09-17-2011, 11:49 PM
SSedan64's Avatar
As WD said the 2004R will bolt right up.
Either Trans will require some Upgrades to handle the 455's torque. The 2004R has more parts available for HiPer use. I recommend at the least swapping the stock Forward Drum for a Billet Forward Drum in the 2004R.
They can snap with a mild stock engine> http://www.turbobuick.com/forums/tra...ml#post2826144 then you have 6 neutrals & park.
Old 09-18-2011, 03:09 AM
BZLY904's Avatar
Thanks
Thanks Guys for the help,i will be checking back in with results...
63 Buick Electra 225 Petematthews Suspension - Brakes - Steering 7 02-10-2011 12:33 PM
1962 Buick Electra 225 LT1 Swap crazycasey General Rodding Tech 1 02-05-2010 04:00 PM
73 buick 225 electra buickelectra225 Hotrodding Basics 2 09-08-2009 06:12 PM
73 Buick Electra with a 455 bigdieseltech Engine 9 09-30-2005 10:54 AM
64 Buick Electra ian marsh Engine 2 12-23-2003 04:21 PM
