1970 C-10 Wheel Bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2005, 08:06 PM
I need help identifying my axle for replacing the wheel bearings, (front)... My 1970 C-10 1/2 ton two wheel drive needs them bad... The Manual I have says there were two numbers 603351 for earlier than 1972 and 603333 for later... The local shop says they are either IFS 25 or IFS 30&35... How do I determine which one I have so I can order the right cost?? And where might I find a blow up of this model. the manual only show the 4x4 version... I have'nt done Wheel Bearings in about twenty years and never on this vehicle, but I think I can handle it with a good blow up..
Thanks for your help!
Old 02-11-2005, 08:21 PM
johndoe,
What I would do is order all the bearings and all seals listed. Then return the items you do not use. The other thing you could do is pull the truck apart and take the seals and bearings into the store and have them match them up.
Have Fun
Scholman
Old 02-12-2005, 09:08 AM
Tazz
this may or may not help you..
you can try and get help here... www.chevytalk.com someone may help you and they may not seeing your new but you can ask.
Tazz
Rat Rods Rule!
Old 03-09-2005, 06:25 PM
one word NAPA
