1970 Cadillac 472 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2013, 11:25 PM
1970 Cadillac 472 ?
Sprayed some cleaner along the drivers side of the intake manifold on the engine while it was running. It began to run rough. Leaking intake manifold gasket ?
Old 05-29-2013, 11:58 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Yeap or a vacuum leak in a hose
Old 05-30-2013, 03:15 AM
Faith - Respect - Trust
Sounds like a vacuum leak...try spraying a flammable substance over the same area...sometimes your idle will increase...then you know you have a vacuum leak.
Old 05-30-2013, 07:32 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
...but not on the distributor...
Semper Fi
Old 05-30-2013, 08:54 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
Yeah the best way to start a fire on a caddy is with your lincoln welder. Ask me how I know.
Old 05-30-2013, 10:23 PM
techinspector1's Avatar
Wiki Edits: 326
Best way to incur personal injury is to use an acetylene ax to cut exhaust system components out of the way, while laying on your stomach and wearing a NYLON jumpsuit. Ask me how I know.
Old 05-30-2013, 10:34 PM
Wiki Edits: 326
The motor ran rough because as it was sitting, the fuel/air mixture was correct and you upset it by spraying and richening the mixture. In other words, whoever tuned the motor, tuned it to run rich from a carburetor standpoint, but just right when the air from the leak was included.
61 Cadillac deville, 472 swap??? theallmightymonkey Engine 8 04-18-2012 11:21 AM
1955 Cadillac 472/500 Swap Help Bill Klooster General Rodding Tech 2 08-31-2008 12:50 AM
500/472 Cadillac tranmission alternative 49lincoln Hotrodding Basics 6 05-17-2006 03:46 PM
Fixing up a Cadillac 472 Cardan Introduce Yourself 2 12-04-2004 04:57 PM
Cadillac 472 dilema strtsquirrel1681 Engine 5 08-13-2002 09:45 AM
