Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 Camaro SS with KM Speedo
Old 04-23-2005, 08:15 AM
dollybud's Avatar
dollybud dollybud is offline
Where you are do they use the metric system? Cranking back below the "o" is no answer. If you want to stay with the KM's change the speedometer cable gear to compensate for the 20 km its out. MPH to KM and KM to MPH is simple math. Check the Knowledge Base for info on the gears.
Tom
