1970 chevelle 396 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2005, 11:03 PM
There all made to drive!
1970 chevelle 396
OK, I have aquired a 70 ss chevelle 396 (for free) and I know it's 100% original. the problem is I thought the 396 ended in 69 and it was replaced with a 402. I found the build sheet to show a 396. Is this a standard option
or is it a rare option? Also does anyone know the L- name for the 396 compared to the LS-6 454? Thanks for any help!
Old 11-29-2005, 11:13 PM
I had a black 70 Chevelle SS..........two as a matter of fact....
1 was a LS-6 car and the other was a SS El Camino....black also...
the 70's were 402......but Chevrolet still called them 396's
A 402 is just a 396 bored .030 over..from the factory
Old 11-30-2005, 04:39 AM
KNIGHT07731's Avatar
1970 chevelle 396
ask here www.chevelles.com go to the forum, and ask in athe engine section
Old 11-13-2009, 04:05 AM
L 78 396 for 70 Chevelle
396's were in 70 Chevelle's. I have an L78 396 that was manufactured in the fall of 69. It was destined for either a Chevelle, Camero or Nova. The L78 model is the hi-perf edition and was rated at 375hp in the Chevelle's though the rating for virtually the same motor in the Corvette was rated at 425hp. You can run down the numbers on the front of the block and the rear of the block and then google big block chevrolet specs and you will find a page that tells you what your motor was rated and what it likely came in. Lot's of info out on the intranet on these motors. I also have a friend with a speed shop in Pensacola that has the same Chevelle as yours with the original motor and it's the same L78.
Old 11-13-2009, 05:52 AM
Correction, your friend HAD a chevelle. how do you think this guy acquired it 'for free'? haha, just kidding. Had to throw that in there. Nice job scr*wing over the previous owner on the chevelle! Either that person reeeeeaaallly likes you or --- umm... yea, let's leave it at that.
Old 11-13-2009, 06:18 AM
BOBCRMAN@aol.com's Avatar
I bought a new Nova (an ordered COPO car) Ist part of January 1970. The engine was called a 396. It actually was a 402. 4-bolt. Rectangle port heads. Engine built in late 69.
Easiest way to tell if the engine is "original" is to look at the intake manifold. All 70 big blocks used the new peanut spark plugs (5/8 tapered seat). Also had the low Corvette style intakes.
A solenoid activated vac advance operated by a switch on the trans so vac advance only happened in high gear.
I have seen many "fakes" represented as big block originals. Even in the enthusiast magazines. Easy to spot if you were there when they were built.
68 chevelle SS 396 Icemanmd Hotrodders' Lounge 2 10-24-2003 09:34 AM
1970 Chevelle 307 - 17000 miles! Numbers a70malibu Engine 1 01-11-2003 02:53 PM
Finally found out the real story on my dads 396 chevelle that he once had... stonedchihuahua Hotrodders' Lounge 3 12-08-2002 11:38 AM
1970 Chevelle Malibu 17000 Miles!!! a70malibu Hotrodders' Lounge 8 12-04-2002 05:16 PM
