Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 chevelle engine wiring
Old 12-27-2012, 10:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by crownver View Post
I thought if you had points you need a resistor to keep the points from burning.
You do. GM went to a resistance wire needed for the points-type ignition system, instead of using a ballast-type resistor.
Whether a resistor (wire or otherwise) is needed or not depends on the type of ignition system being used and the coil resistance.
