Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 chevelle engine wiring
  #16 (permalink)
Old 01-22-2013, 04:47 AM
EOD Guy's Avatar
EOD Guy EOD Guy is online now
Depending on what was done before you got it...... One large cable to the battery, purple wire from the ing, yell or off white to the coil. The other wire you see on the dia is the braided wire that runs from the soleniod to the actual starter motor.
Earlier in the post someone wrote that the resistance wire is so that the points won't burn up if you left your key on etc...... maybe true but......... The resistance wire is so you won't burn up your coil.
