Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 chevelle engine wiring
  #17 (permalink)
Old 01-27-2013, 07:24 PM
crownver crownver is offline
If it's a stock floor shift set up, I would thing that there'd be a purple wire with white stripe to where the shifter would be if you had one. Also should be a purple wire there. Those are the ones I meant for you to jump, while turning the key to start.
