Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 01-15-2006, 11:25 PM
tombo615's Avatar
tombo615 tombo615 is offline
1970 chevelle ss 12 bolt
did the 1970 chevelle ss come with a specific gearset for the 12 bolt or was it just a dealer option? im asking for a friend of mine who recently purchased this rear with stock ss gears in it
any help would be appreciated
Old 01-16-2006, 05:39 AM
k-star k-star is offline
Jesus saves
gears
Without looking in my book,,, I am just going from memory here.. I think the 70 chevelle ss was available with any gear from 2:73's to 4:88's So you will need to tell us the code from the axel tube on the front side of the rear. Then it's only good if no body in the last 35 years changed the ratio...
Keith
K-Star Automotive
Performance Engines
The crash was easy: rehab is killing me-"John Force"
Old 01-16-2006, 06:22 AM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 5
re: 1970 chevelle ss 12 bolt
If no one specified whrn ordering, it probably has 3.08s or 3.23s.................Take the cover off and check the gears. Probably time o change the fluid anyways.
Old 01-16-2006, 08:04 AM
Pick Pick is offline
My brother's 70 Chevelle SS396 4-speed car came from the factory with 3:73 posi. Easy enough to pull the cover off and check.
Old 01-16-2006, 01:14 PM
tombo615's Avatar
alright looks like i'll have to do that
how exactly do i count the gears though? i was showed a long time ago and i forgot how to tell
Old 01-16-2006, 04:33 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Put a mark on the ring ( the big gear ) and turn it and count the teeth.
Repeat on the pinion ( the small gear )...
Take the big gear number and divide by the small gear number....
EXAMPLE 41 divided by 10 = 4.10
Old 01-16-2006, 09:13 PM
jimfulco jimfulco is offline
Look around the edge of the ring gear and you will likely find 4 numbers, most likely 2 digits each, that will tell you the tooth count of the ring & pinion gears and the month & year of manufacture. For example, if you see 41 10 12 70, you have a 41:10 (4.10) gearset that was manufactured in December of 1970.
Old 01-17-2006, 06:22 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
. . . and according to all of my sources, limited-slip/posi was NOT an automatic option on the Chevelle SS.
It had to be specifically ordered.
Old 01-17-2006, 01:09 PM
Don't recall anyone saying it was.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1970 chevelle ss 12 bolt"
the history of chevy v8's savman1 Engine 30 01-25-2008 01:02 PM
10 bolt vs. 12 bolt. Iwanttolearn Transmission - Rearend 4 02-05-2005 10:32 PM
Chevelle 12 bolt axle spline count JamesRS Transmission - Rearend 4 10-23-2004 10:21 PM
Would it be possible to shorten 12 bolt? shockers69 Transmission - Rearend 4 01-05-2004 01:03 AM
How to identify Oldsmobile 12 bolt? elukas Transmission - Rearend 8 12-13-2003 10:59 AM
