A week ago diaphram busted in fuel pump filling engine with gas. Drained all of it out and changed oil twice, starting for a couple seconds in between oil change. Running fine this morning but tapping from under valve covers. Found three valves loose and tightened them up. Now motor wont even attempt to crank. New battery so its got plenty of juice. What could be my problem? Thanks in advance, Jim
Sounds like you were hydro locked. Are the floats stuck now? Do you have fuel running down the carb when cranking? After cranking, pull the plugs to see if they're wet.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
