1970 Chevy 402 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2006, 10:21 PM
mejias's Avatar
"Electrical Lineman"
1970 Chevy 402
I have a 1970 GMC p/u that I purchased last weekend. The owner said that they were cruising down the freeway in Houston. All of the sudden the truck shut off. They tried to restart it and the motor sounded like it had seized. They towed it home; dropped the starter and exchanged it @ O'reilly. They put the starter back on. They fired the truck up; but, it was making a loud screeching whine. They shut it down. They tried to figure what the noise was. They again attempted to start the truck and once again it didn't spin over. They took it over to a shop and the mechanic told him the motor was locked up!!!! I removed all the belts when I got it home. I spun the motor over; but, it was dragging. I placed the battery on a charger. I tried to start it again a few hours later and it did not spin over. I don't know if I need to pull the motor or not....The owner had been driving this p/u for the last 4 years w/o a problem.(Up until the day it died.) Can anyone help?Email me at
mejias@awesomenet.net
Old 04-20-2006, 10:47 PM
Jmark's Avatar
It could be as simple as a rock kicked up between the flywheel and the block, to a spun bearing causing the noise and subsiquent lockup. Could even be a converter problem too. Might try taking the 3 converter bolts out and sliding the converter back and try turning it again.
Mark
Old 04-23-2006, 07:15 AM
mejias's Avatar
The bad news......
I dropped the oil pan....It did spin a bearing. The front of the engine was completely dry. It was not getting oil for some reason. I am pulling the motor this morning.....Thank you for the tips....Joel
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Restoring A 1970 Chevy Truck bnewlun@8549aol.com Introduce Yourself 2 07-10-2004 10:01 AM
Chevy sending unit in a Ford Tank AnD Engine 0 05-14-2003 04:34 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
