1970 Chevy Engine Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 07:54 AM
ZEX750's Avatar
WANTING TO PUT A 588 BBC IN A 1970 CHEVY 4X4 JUST WONDERING IF THERE IS ANY MODS THAT NEED TO BE DONE OTHER THEN THE TRANS TO HANDLE THE POWER AN THE 33X12.50s
Old 01-14-2012, 08:04 AM
Last journal entry: update
You should probably be asking this at pirate4x4.com
Old 01-14-2012, 09:51 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
why, do you think nobody here has a 4x4 chevy truck?
I used to have a monster truck with rockwell axles and 52" tires!!!!!!
if it is 1/2 ton you will need to beef up everything (depending on which transfer case you have)
3/4 ton and up, maybe front axle and transfer case
just need to know what the rest of the trucks running gear components are
what the intended uses will be
Old 01-14-2012, 11:26 AM
ZEX750's Avatar
dont have the truck yet but looks like a 3/4 is the better way to go what is your advice for the whole nine yards will be used as a on road /off road truck motor should be around 700hp
Old 01-14-2012, 11:47 AM
& matts38chev
it will be a lot of work
chevy engine swap Rodknocker47 Engine 10 10-28-2011 11:16 AM
1970 8.2 10 bolt BOP carrier swap poy41 Transmission - Rearend 37 08-23-2009 07:55 PM
1970 chevelle big block swap ??? alteredpilot General Rodding Tech 1 07-23-2009 10:21 AM
1970 c10 i6 to v8 swap, how hard? chr15 Engine 2 08-06-2005 07:27 AM
1970 8.2 Rearend Swap Ken44 Transmission - Rearend 2 12-25-2002 11:37 AM
