Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 elcamino
Thread: 1970 elcamino
Old 11-24-2004, 11:28 PM
brandon72887's Avatar
brandon72887 brandon72887 is offline
i have checked that and ran others
i have checked that and ran others from different curcuts on the fuse block it gets a full 12 volts it is wierd because the car will run fine for about two weeks then everything will short out and when i replace the dist. it will take off runing again except for this last time
thank you for your reply
