1970 ford 302 valve adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2002, 03:49 PM
Question 1970 ford 302 valve adjustment
i have a 1967 mustang with a 1970 302 v-8. i'm confused about adjusting the valves. everything i know about doing this adjustment says that the rocker arm stud nut should be fairly hard to turn, so that it won't move once it's been set. all of the rocker stud nuts i have spin quite freely. i ordered 16 new nuts from ford, part number d0az-6a529a, but they, too, spin quite freely.
shouldn't these nuts be somewhat hard to turn, and if so, where can i find the proper nuts?
tia
coolBreeze
Old 08-16-2002, 09:44 PM
aka Duke of URL
Arrow
[quote]1970 302 v-8<hr></blockquote>
You have positive stop rocker arm studs and adjustment is only possible by collapsing the lifter and checking valve lash. U/S and/or O/S pushrods are then used to get the desired lash.
You will either have to go to screw in studs (same as mechanical cam) or use the earlier press in studs and rocker arms.
Old 08-20-2002, 03:32 AM
48fordnut's Avatar
Post
inyour situation just use the same instructions out of the motor manual, tight then 1/4 turn more.
