1970 Gto - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2010, 12:51 PM
1970 Gto
Anyone know what speedometer gears go with a 70 gto with a 140 mph speedo . I don't have the same trans it came with and its about 40 mph off. Thanks!!!!
Old 03-31-2010, 12:21 AM
http://novaresource.org/speedo.htm has the formula you need. You need your tire diameter and rear axle ratio to plug into the formula. Once you find out what speedo gear ratio you need, look at the chart to find out what gear combo will get you the closest. Gears are cheap at your local dealer or online.
http://novaresource.org/speedo2.htm has more gears.
Old 03-31-2010, 06:46 AM
70 gto
Would this work with a 140 mph as with 120 like most . Thanks
Old 03-31-2010, 07:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
it does not matter if it is a 85 mph speed-O or a 200 mph unit... the gear ratio for the speed-O gears must be figured by the proper formula as posted by the member here
Old 04-01-2010, 09:05 PM
No problem. It even works on Fords.
Old 04-01-2010, 09:37 PM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
They are right, the speedo doesnt care if its 120, 140 or 160, it just cares how many revolutions the driveshaft and output shaft are turning. If you swap a 120 for a 140 and they are both calibrated correctly, that is the only thing you need to change. It will work and be accurate as long as the gears in the tailshaft are formulated to work with the final drive and tire diameter.
Old 04-01-2010, 10:33 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If your speedometer was correct with the old transmission, you need the same gear that was in it.
Old 04-02-2010, 11:44 AM
1970 gto
Not good in math can't get it to work out for me. I have 3.55 rearend gears 25in tire. Thanks Steve
1970 GTO has no power??? silverjess Engine 13 08-14-2008 04:48 PM
pontiac YA 455, coded for 1970 GTO, loading up Gladis Engine 3 04-07-2007 12:52 PM
search for 1970 Pontiac GTO titomytito Introduce Yourself 2 11-07-2006 05:26 PM
Pontiac will drop GTO this year ckucia Hotrodders' Lounge 10 02-22-2006 10:44 PM
1970 pontiac gto judge ram air 3 gothamtech General Rodding Tech 6 12-26-2003 12:35 AM
