Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 GTO Nose/Front End
Old 11-14-2012, 12:47 PM
BarryK's Avatar
BarryK BarryK is offline
Originally Posted by Dayo5 View Post
I am getting ready to start prepping the body for paint, as you can see from my profile pic, the nose is in good shape, but weathered. Should I spray it with primer filler and see what it looks like? Or should I try to use filler to smooth it out first? Thank for your inputs!
No on all accounts, if you are talking about the endura bumper, the micro cracks will come through the 2K primer, just a matter of when.
Also, it must be stripped.
Also NO polyester should ever come in contact with the bumper itself or it will bubble, only a matter of when.
Only thing that touches the bumper is a two part plastic repair for the bad spots, like Duramix 4036, 4040, 4030, Sem, 3M or other like products.
Any paint rep that says treat like any urethane bumper, most likely has no clue what one is.
All polyester is only to be used over epoxy as a barrier-coat.
Use no solvent borne cleaner or adhesion promoter.
