1970 impala...battery dies if i dont start it everyday. - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 01-01-2011, 11:00 PM
EOD Guy's Avatar
Forgot to add.... this is for an external regulator
  #62 (permalink)
Old 01-03-2011, 04:43 AM
EOD Guy's Avatar
BTW the two screw on terminals on the horn relay are the same piece of metal .....connected.
  #63 (permalink)
Old 01-04-2011, 02:21 PM
one of the wires on the relay is the draw ???
the wire connected to the screw on the right is the draw , what would this connect to,,,,,,,,,,,,,,btw when i disconnect this wire the car will turn off
  #64 (permalink)
Old 01-04-2011, 04:41 PM
do you know what connects to the screw on the right on the horn relay???
Originally Posted by kc8oye
thank you
this sucks
  #65 (permalink)
Old 01-04-2011, 05:18 PM
EOD Guy's Avatar
Unless someone's hacked it it either goes to the fuse box connector or to the factory splice/crimp (located under all that tape) which then is connected to the alt and the lug on the radiator support and the voltage reg and the battery.
  #66 (permalink)
Old 01-04-2011, 05:41 PM
EOD Guy's Avatar
That 20g blk wire from the horn relay to the fuse box connector.... continues to the steering column connector
  #67 (permalink)
Old 01-04-2011, 05:43 PM
EOD Guy's Avatar
The 16g Red wire goes thru the connector and supplies pwr to the fusebox, the ing switch, the wiper switch and just about everything else that needs pwr.
  #68 (permalink)
Old 01-04-2011, 06:34 PM
thanks
i guess i gotta pull all the fuses again... back to square 1
  #69 (permalink)
Old 01-04-2011, 06:51 PM
EOD Guy's Avatar
I'd start by pulling the steering column connector.....
  #70 (permalink)
Old 01-04-2011, 07:49 PM
sqzbox's Avatar
My pipes are my music
DOES....THE...HORN...WORK?
  #71 (permalink)
Old 01-05-2011, 04:59 AM
EOD Guy's Avatar
I'm thinking the reason the car dies when you remove the wire is due to the battery being dead, or not enough juice to keep the car running and when you pull that wire it quits exciting the alt to produce output.
sqz might have pin pointed your drain...... horn wire from under the dash area
Earlier in this thread was a most excellent wire dia of a charging system ...... you might want to redo what you have now into something similar to the diagram.... for example the blue and white wires you capped off..... those are the wires that run from the alt across the radiator support to the volt reg and are used to excite the alt etc......
  #72 (permalink)
Old 01-05-2011, 11:39 AM
i unplugged the horn at the steering wheel
ima check under the dash right now!!!!!!!!!!!!!!!!!!
  #73 (permalink)
Old 01-05-2011, 06:04 PM
sqzbox's Avatar
You unplugged the horn under the steering wheel? If the wire or connector is touching anything...honk honk.if the horn doesn't honk......drain drain.
It happened to me with a brand new battery.
  #74 (permalink)
Old 01-08-2011, 05:42 PM
EOD Guy's Avatar
Did you get it fixed?
  #75 (permalink)
Old 03-03-2011, 07:14 PM
EOD Guy's Avatar
Did you ever get this fixed? I switched my external reg over to a new internal reg and I'm having the exact same problems you are having...... Batt goes flat in a day or so..... Did your alt get hot to the touch even without the engine running?
1970 Impala header clearance problems ChrisMiddleron Engine 5 09-18-2006 11:23 AM
can't get the Impala to start 1eyedjak Engine 15 09-11-2006 10:59 AM
64 Impala Remote Start Question EazyDuzIt102 Electrical 2 06-27-2006 10:51 PM
1965 Impala Wont Start EazyDuzIt102 Engine 2 09-04-2005 06:57 PM
My first Kandy Paint-job 1970 impala ChrisMiddleron Body - Exterior 48 03-28-2005 10:38 PM
