1970 Impala Disc Conversion - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-31-2010, 07:00 PM
freedom53's Avatar
Last journal entry: A Few Years Later...
Rotors??
I have a set of D/B from a 70 impala on my 65. As you can see from the pics the rotors mount on the rear of the hub and are held in place by the bolts press-fit into the back of the hub. I have not been able to find a reasonably priced replacement rotor. They are considerably more expensive than the average and not very common.
ID:	43574   Click image for larger version
  #17 (permalink)
Old 02-05-2012, 11:25 AM
Originally Posted by bobscogin
'69-'82 Corvette spindles / brakes make a nice swap. Did it on my '65 Impala. Get everything between the upper and lower ball joints, but use the Impala steering arms.
Bob
Hey Bob,
Just found this thread while researching disc brake options for my '70 Impala, excellent idea! I have also found the same idea explained elsewhere on line.
I have a couple of questions about this:
Does the Vette set-up put the wheel in the same location in the wheelwell?
Since the Vette and Impala spindles are the same part number, why not keep my stock Impala spindle?
Is the spndle a wear item, should I go for a new one justto be on the safe side?
  #18 (permalink)
Old 02-05-2012, 12:13 PM
As far as I can tell without actually measuring, the wheel track remains the same. If the part numbers for the Corvette/Impala spindles are the same, I guess you could use the Impala spindles. I bought the Corvette brakes as an assembly--everything between the upper and lower ball joints. So I just used the Corvette spindles. Spindles aren't an expendable part, so unless there's specific damage you don't need "new" ones.
Bob
  #19 (permalink)
Old 02-05-2012, 01:54 PM
if memory serves me correcty: vette and impala spindles are the same but not hub and roter, vette roter mounts on the outside of hub. impala mounts on inside of hub therefore u will track 1/4"-7/16 wider on each side if u go with vette roter. i have a 65 impa and put 70 disk brake setup on it . all components mounted like butta. stops on a 25 cent piece, no pullig, verry happy. impa roter and hub still availible new as well as spindle. just gutta do some diggin. hope this helps.........................
  #20 (permalink)
Old 02-05-2012, 02:14 PM
Thanks for these infos!
Since budget is an issue for me, I will then keep my Impala spindles... With Corvette rotors, hubs and calipers. I have not been able to find new Impala rotors or very expensive: a few years ago, I found some 2000 miles from me, for $700 the pair!... Future maintenance will be much easier with Corvette parts!
Something else I have learnt is that there is a problem with the stock Corvette calipers corroding, so I will need aftermarket calipers...
  #21 (permalink)
Old 02-05-2012, 04:29 PM
Just another question!
If I go with stock Impala spindle and Corvette hub/rotor, which wheel bearings do I use, Impala or Corvette? Or are they the same?
Thanks!
  #22 (permalink)
Old 02-05-2012, 05:10 PM
any auto parts retailer will give u part #s ie napa
  #23 (permalink)
Old 02-05-2012, 09:25 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
1975 Corvette:
(You guys said 69-82 same) Corvette front rotor.
NAPA Part# NDR 4885748
Attributes
# of Bolt Holes : 5
Bolt Circle Diameter : 120.65 mm/4.75"
Brake Rotor Diameter : 298.5 mm/11.76"
Brake Rotor Discard Thickness : 30.86 mm/1.22"
Brake Rotor Thickness New : 31.8 mm/1.26"
Center Hole Diameter : 71.5 mm/2.82"
Height : 78.7 mm/3.1"
Vented / Solid : Vented
Brake Pads:
Part # AE-727 (organic)
Calipers:
Part #'s 242-2062 (LH), 242-2063 (RH)
Attributes
# Brake Caliper Pistons : 4
Bleeder Screw Thread Size : 5/16 X 24
Caliper Piston Material Type : Metal
Contents : Pads Not Included
Finish : Rust Preventative Finish
Inlet Size : 7/16 X 20
New Components : New Dust Boots, OE-Style Seals, O-Rings, & Bleeder Valves
Wheel Bearings:
Part # UBS BR5 (SKF Bearings) Inner Cup & Cone
Attributes
Contents : 1 Bearing
Wheel Bearing I.D. : 1.3750"
Wheel Bearing O.D. : 2.5630"
Wheel Bearing Type : Tapered
Wheel Bearing Width : 0.7100
Part # UBS BR3 (SKF Bearings) Outer Cup & Cone
Contents : Cup & Cone
Wheel Bearing I.D. : 0.8437"
Wheel Bearing O.D. : 1.9690"
Wheel Bearing Width : 0.6900"
Seal:
Part# UBS 19768 (C/R Seal)
Attributes
Wheel Seal I.D. : 2"
Wheel Seal O.D. : 2.631"
Wheel Seal Width : .234"
1970 Impala
Rotors:
Not available
Classic Performance has a #2704, 2704UG kit that fits stock spindles
Pads:
AEC-728A (Application Engineered Ceramic)
Calipers:
242-2012 LH, 242-2013 RH
Wheel Bearings:
BR5 / BR3 (same)
Seals:
19768 (same)
Part #'s provided are based on the information as I understood it.
Use at your own risk.
"NAPA Don"
63 impala simple disc conversion PikFabrications Suspension - Brakes - Steering 21 01-05-2008 03:12 PM
63 chevy impala disc brake conversion 63impala Suspension - Brakes - Steering 3 09-02-2007 11:01 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
