1970 impala t-350, reverse only - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2011, 10:54 PM
Hey guys I have a 1970 impala and my transmission has recently started going only in reverse ..no drive but the funny thing is when I bring it all the way to my lowest gear it goes back in reverse. I thought it might be low on fluid because this has happened before when I was low on fluid,it is a turbo 350 and has never given me any issues other than what I listed above I appreciate any suggestions or help thanks.... H20
Old 06-27-2011, 06:24 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title. Try to put in vehicle information on the thread title so the folks here have a better idea what your question is.
Since you have reverse, this tells me the pump is working enough to move the car. It also tells me the input shaft is receiving power from the engine.
I suspect you have a forward clutch problem.
Have you moved the shifter all the way to manual "1" to see if the car will move forward?
When you run a trans low on fluid, often the first clutch pack damaged is the forward clutch in a t-350
Old 06-27-2011, 01:10 PM
Turbo 350 transmission problems
Yes..when I put the shifter all the way to first it goes back in reverse...if it is a clutch issue is that something I can do myself or is it time for a rebuild..and if so should I pay full price for a rebuild or try to just have the clutch replaced..thanks H20
1970 Impala Disc Conversion clance54 Suspension - Brakes - Steering 22 02-05-2012 08:25 PM
battery dont charging impala 1970 impala-turkey Electrical 45 06-02-2011 11:39 AM
i have alot of slack in the steering..1970 impala logic-ali Suspension - Brakes - Steering 1 12-12-2010 07:54 AM
1970 impala window parts jrp Interior 2 05-21-2007 10:01 AM
My first Kandy Paint-job 1970 impala ChrisMiddleron Body - Exterior 48 03-28-2005 09:38 PM
