1970 Lincoln Mk III rear end question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2010, 07:45 PM
retiredfireguy's Avatar
I have a rear end from a 1970 Lincoln Mk III. It has a 9 3/8" center section with 2.70 gears, and 31-spline axles. I am replacing the center with a 9" 3.70 limited slip unit. Anyway, there are some kind of gadgets located on the ends of the axles, by the brakes. There are wires coming out of these things. I have to guess that these units are sensors for something, but I don't have a clue what. Does anyone know what I'm talking about? Since this rear is going into a '27 Ford roadster, I really don't think I will be needing these things. So can I just remove them and forget them, or will I be kicking myself later? Thanks
Old 01-29-2010, 07:52 PM
ericnova72's Avatar
More for Less Racer
I'm not sure what they are, but for a generic application like yours you can ignore or remove them, they would only be of use to an installation in the original Lincoln. May be some type of "E-brake left on" sensor or or pad wear sensor.
Old 01-30-2010, 01:57 AM
SSedan64's Avatar
Some of the Lincolns had "Skid Control" that may be what the sensors are for.
http://www.fordification.com/tech/rearends_ford05.htm
http://www.fordification.com/tech/rearends_ford08.htm
Old 01-30-2010, 10:54 AM
Skid control...That's what those things are for. Thanks for the info!
Old 01-30-2010, 04:17 PM
ericnova72's Avatar
More for Less Racer
Interesting info, I guess "ABS brakes" aren't as newfangled technology as the car companies would like you to believe
Old 01-30-2010, 04:40 PM
You guys got me curious, so I did some Googling and found an article in Hemmings, where I spotted the following quote: "An advanced safety feature came on every Mark III in 1970 - the Sure-Track Brake System offered rear-wheel-only anti-lock braking down to four mph". Mystery solved. Thanks again.
Rear End vibration driving me insane 973kgt Transmission - Rearend 41 11-13-2008 11:01 PM
'70 Lincoln Mk III - Heated Seats?? Rustydawg Electrical 0 08-26-2008 09:54 AM
67 camaro rear end question shclayto Transmission - Rearend 6 10-11-2005 09:24 PM
Monte SS rear end question. Mike_82 Transmission - Rearend 10 08-18-2005 05:53 AM
Lincoln Mark V rear end - what's it worth? 67cougar-gt Transmission - Rearend 3 09-22-2004 12:42 AM
