Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 nova changing 8.2 to 8.5 soon
Old 02-25-2011, 05:31 AM
gearjammer38 gearjammer38 is offline
Last journal entry: Unpacking
Originally Posted by ericnova72
Check out Yukon gears, axles and Yukon Duragrip positraction units. One good source is Randy's Ring and Pinion.
Avoid Auburn posi units, and stock GM Gov-Loc units from the 1980's. Factory Eaton posi units from the 70's are good if you can find one, but they can be worn out and need new clutches so watch for that if you do find one, as rebuilding it will add to the cost.
i actually have a GM Grenade-Loc in my basement, i bought it for $20. after doing some research on it i decided to not use it. im looking to buy a newer posi off summit or some other company, im just looking to see whats the best one to go with, again i dont need a top-of-the-line one, just one to suit my needs
