Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 nova changing 8.2 to 8.5 soon
Old 02-25-2011, 10:31 AM
cranky1's Avatar
cranky1 cranky1 is offline
Just stuck
Any time you weld on a rear end, you're going to get some movement. As for a jig, I don't weld with mine in place but I do stick it in to see which way it moves then weld accordingly cause if you weld with the jig in place, you might end up having a hard time getting it back out. And if I'm welding on new bearing housings....they are welded last.
