Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 nova changing 8.2 to 8.5 soon
Old 02-25-2011, 11:21 AM
gearjammer38 gearjammer38 is offline
Last journal entry: Unpacking
Originally Posted by cranky1
Any time you weld on a rear end, you're going to get some movement. As for a jig, I don't weld with mine in place but I do stick it in to see which way it moves then weld accordingly cause if you weld with the jig in place, you might end up having a hard time getting it back out. And if I'm welding on new bearing housings....they are welded last.
can you go into more detail about this? whats on the inside? is that just a thick bar? does it run the entire length of the housing?
