Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 nova changing 8.2 to 8.5 soon
Old 02-25-2011, 03:52 PM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
http://mittlerbros.com/rear-end-narrowing.php This is the housing fixture that I use now. I used a borrowed one that was made by a tool and die maker for years and then decided to buy my own. I use it to check the housing, but when welding the tubes to the center casting you don't get much movement in the tubes. I weld about 1 1/2 inch on one side and rotate it to the other side until I get all the way around. I was a DOD aircraft certified welder for about 10 years, so I got pretty good at welding.
