Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 nova changing 8.2 to 8.5 soon
Old 02-25-2011, 05:55 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by gearjammer38
thanks for the help everyone, but i don't plan on narrowing the rear at all or changing to ford 9" ends, this will all be done in my garage by myself so i want to keep it simple and not get over my head. im still a little confused on how to make the "pucks" can anyone post pictures?
This will require a machinist and a lathe to make them. Round stock turned to the proper OD to match the OD of the bearing race, then drilled and reamed or bored hole through the center match the diameter of your center bar. Mine are 1-1/4" thick.
Like a hockey puck with a hole through the middle, and the outside turned to the size of the bearing bore it is going into.
