1970 nova front drums - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 08:26 AM
I want to convert the front brakes of my hot rod to disk.. The front is a 1970 nova ,,, What is the best and least expensive way to do it
Old 04-04-2013, 08:43 AM
kso's Avatar
kso kso is offline
Search around for an original Nova single-piston set, any '73-74 (when discs became standard but the frame was still the same) will have them and is the most common (also Omega, Ventura, Apollo), after that the '69-72 Chevelle/GM a-body cars will fit if the steering arm is changed. Probably least common is the actual '69-'72 Nova optional disc application which of-course will bolt in. Naturally you have to get the lines, m.c., prop valve etc. and do the standard rebuild stuff.
Don't get earlier ones because they're four-piston and more complex, don't get later ones (either Nova/x-body or Chevelle/a-body) because the spindles are different.
After that, if you can't find any of those, just get out your wallet 'cause lots of people sell new sets.
Old 04-04-2013, 01:20 PM
The least expensive way to do it is to buy the repro caliper brackets (something like $40/pair or so), mill down the boss on the spindle per the website below, and just get calipers, rotors, hoses, and master cylinder from any auto parts store. Get one of the new brass combination proportioning valves. Plumb and bleed, you''re done.
Converting Drums to Disc Brakes
front drums on a 23 T Sv23T Suspension - Brakes - Steering 13 05-24-2010 04:04 PM
Front Disk Brakes on 1970 Nova Skern Suspension - Brakes - Steering 12 05-28-2009 10:48 AM
36 terraplane front break drums amc360 Suspension - Brakes - Steering 2 04-04-2008 08:02 PM
I need help with my breaks,swap drums to discs 1974 chevy nova lovethehotrods Suspension - Brakes - Steering 4 11-30-2006 09:12 PM
Front Drums to Disks on 68 Cutlass Barz51 Suspension - Brakes - Steering 4 12-26-2002 09:32 PM
