Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1970 Olds 455 not sparking
  #16 (permalink)
Old 06-25-2012, 11:02 PM
RWENUTS's Avatar
RWENUTS RWENUTS is offline
Originally Posted by Trans Am Tony
Thanks for all the replies. I tried the jumper wire, still no spark. I have 11.34v with the ignition on, and 8.9v while cranking. I called the parts store and told them about the problems I've been having, and they said the points may be bad. So, I think it all might be a bad reman distributor........
"Hencho in Mexico"..............
TRy one more thing with the jumper wire. Unhook the wire that's on the positive on the coil and use the jumper wire only. If it runs you'll need to pull the jumper wire off to shut it off.
