So, I shouldn't even have to bore it out at all, you're saying I could probably get 700 HP just with the boost and adding stronger parts, aluminum heads, etc. I probably wouldn't want to bore it anyways if I'm taking the compression rating up. Most propane run at about 17:1, don't they?
Someone told me you can't run a propane set-up with EFI, is that true do you know?
