1970 Roadrunner - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 11:57 AM
1970 Roadrunner
Can someone tell me how to tell if my 70 Roadrunner came from factory with a Dana rear? Thanks a lot!!
Stiffy
Old 01-20-2011, 12:02 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You can start here. http://www.mymopar.com/6971opcodes.htm .
Does the center section load from the front or the rear and does it have a rear cover plate on it ?
Cole
Old 01-20-2011, 04:01 PM
BOBCRMAN@aol.com's Avatar
Most came with 8 3/4" rear. Hemi cars were Dana.
Old 01-21-2011, 10:50 PM
Was it maybe just Hemi & 440-six pack 4 speeds?
I had a 70 Challenger RT 440-six and it had a Dana 60 4.10.
Old 01-22-2011, 11:58 AM
Wiki Edits: 49
On the fender tag check for the following codes:
D56 = B&E-Body 3.54:1 "Dana 60" Rear Axle (69-71) HOWEVER, this code could also be B&E-Body 8.75" 3.55:1 Rear Axle (69-71)
D58 = 9.74" 4.10:1 "Dana 60" Axle (69-71)
D59 = B&E-Body 9.75" "DANA 60" 4.56:1
If your fender tag indicates an original 383 (E65) then you can be almost certain (99.9%) that your car came from the factory with an 8 3/4" rear end.
Centerline
HotRodsAndHemis.com
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower." Mark Donohue
roadrunner 1973roadrunner Introduce Yourself 1 08-27-2010 03:32 PM
What to do with my 73 roadrunner Mopar73 Body - Exterior 8 08-26-2010 09:38 PM
need help with vibiration in roadrunner chandlerrambler Engine 3 02-15-2007 04:30 AM
440 into roadrunner frankieJr48 Engine 6 09-15-2005 06:05 PM
EZ Wire kit into 68 roadrunner pete379 Electrical 8 07-17-2003 09:17 PM
