1970 SBC Engine Temperature - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2006, 04:39 PM
I tried to search this topic and had no luck with my scenario....
I have a 1970 SB350 that is carbureted. Does anyone know what engine temperature I should be running at? I heave heard 180-200 degrees is normal, some other people have said 200-220 is normal. What would be considered "over heating"? I just installed a new aluminim radiator w/180 deg thermostat and it is running at 185-190 all day long. I just want to know for the upcoming summer months what would be an "over heating" temperature for this block?
Thanks....
Old 03-24-2006, 04:55 PM
Typical would be a 195 thermostat. If your running a thermostat with a setpoint of 195 or for that matter 180, and it's running higher than the setpoint technically it's overheating. Meaning the cooling system is not maintaining setpoint, or the thremostat is off. If temps get into the 230 range your heading for trouble. 250 your boiling over.
Old 03-24-2006, 09:39 PM
So if I am staying below 200 degrees this summer, I am well within a safe operating temperature.
Old 03-24-2006, 10:34 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If you stay below 230 you should be in a safe range. In a 50/50 mix with a 16 lb radiator cap, 230 is the approximate boiling point.
Anywhere from 190 to 220 is a really healthy range for an engine. Many drivers get nervous and try to keep it cooler, but the engine is perfectly happy as long as its not boiling
Old 03-24-2006, 11:24 PM
I would much prefer to see 200 or below. You have to remember that your oil temp is affected by your water temp. Oil temps will track about 40 degrees higher in a typical street application versus the water temps. You also have to remember what I was saying regarding the thermostat. It's job is to regulate the temp. If the temp does not track the thermostat setpoint the cooling system is not doing it's job as it should. There certainly can be some amount of drift but by no means should you see much if anything greater than 10 degree variation.
Old 03-28-2006, 06:35 PM
Thanks for the input .... I will keep an eye on the temp this summer, typically if it ever were to get over 210 I would probably start getting concerned. I drove it the other day and it never broke 185 degrees around town. With the size of this radiator I am not expecting to many cooling issues this summer
Name:	Tires for sale 010.jpg
ID:	11224   Click image for larger version
Name:	Tires for sale 007.jpg
ID:	11225   Click image for larger version
Name:	Tires for sale 011.jpg
I am considering an SBC Engine Swap jpd37 Engine 7 11-22-2005 05:53 AM
New style starter, old sbc engine? Walker Engine 2 08-14-2003 05:16 AM
need some info about my new(er) SBC engine..... Gino Fultano Engine 3 08-10-2003 06:40 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
