Thread Tools Search this Thread share on Facebook
  #1
Old 12-01-2004, 07:29 PM
39chevy 39chevy is offline
1970 (stock) Muffler Question!
I have a 383, and I got a hold of two free 1970 stock mufflers so I strapped them on (My pipes from my headers are only strapped on for now because I am fine tuning right now) but they sound still quite loud! I have them strapped pretty tight from headers but after muffler there isn't any pipe right now. I'm assuming after I take the car down to the muffler shop and he installs the exhaust correctly that it will quiet up considerbly! Am I right? I was told that these mufflers are really quiet? I do want to use these mufflers if possible, but I also want to have it as quiet as I can get it! Advise, thanks, Dana
Register now (free) or login to remove ads
Old 12-01-2004, 08:03 PM
Max Keith's Avatar
Max Keith Max Keith is offline
mufflers
Thats definately true. When you install the rest of the exhaust, it will get quieter. Especially when you are no longer sitting right over the exhaust outlet.
Old 12-01-2004, 11:35 PM
GoneNova/406's Avatar
GoneNova/406 GoneNova/406 is offline
if you have them hooked to yourheaders and they'er quiet now,chance's are they are too restrictive already.is it 2.5" in dia?do you have a balance tube?you can run your pipes to the back and run two more out the sides in front of the rear tire.i'm ready to put my motor back together now but i am going to try that myself afterwards.
Old 12-02-2004, 07:12 PM
I do have 2.5" pipes, but what is a balance tube?
Old 12-02-2004, 08:36 PM
Ghetto Jet's Avatar
Ghetto Jet Ghetto Jet is offline
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
A balance tube is a piece that connects the two exhaust pipes and balances the uneven exhaust pulses. It helps make a little more power and lowers and mellows your exhaust tone. Balance pipes come in two forms, and H design and a X design. The X is superior to the H because the X design forces the exhaust to blend. But you pay a lot more for the X pipe.
here's some good reading.
http://www.carcraft.com/techarticles/69238/
Old 12-02-2004, 08:43 PM
packratwrecker's Avatar
packratwrecker packratwrecker is offline
Too many hobbies!
Something else to remember, is that the farther forward you put the mufflers, the more 'cackle' you will get, as the exhaust is funneled out through the tailpipes.
If you put the balance tube in front of the mufflers(where it should be anyhow), that will move the muffs back more in line with the stock location. That just leaves the over-axle pipes, and aft sections.
If you are really worried about sound, you can get 'continetal' style mufflers, and put in after the over-axle pipes. That should leave just enough room for some cool chrome or stainless tips.
Old 12-03-2004, 05:42 PM
Those continental style mufflers you talked about, is there a picture somewhere, as to see the size etc? Also where would you purchase these?
Old 12-05-2004, 10:20 AM
Whoops forgot to ask, what is the advantage of installing the x pipe or the H design instead of running my pipes straight back and out the rear, with no H or X? Thanks Dana
Old 12-05-2004, 10:29 AM
Too many hobbies!
What I'm refering to as a 'continental', is also refered to as a 'trash can' by others. Round shell, crimped flat ends. Pretty much a stock style muffler, only round, not oval.
I picked up the saying from an old man I used to know, and everyone around here seems to know what I'm refering to, when I say it.
If you go the the diagram section of any exhaust book, you should be able to find one to suit you needs.
I know a lot of GM full size sedans used them, especially on commercial service packages. (police, taxi, etc)
The advantage of a H, or X pipe is that you greatly increase the available volume of your exhaust system.
I've heard that an X pipe is better for scavenging, but I've never tried it personally. I've installed several H pipes, and they look a lot easier to fit, and install to me.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
