1971 C-10 master questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2008, 07:10 PM
OK-I have questions about a build of my 69 stepsides brakes.I bought a new master and booster for a 1971 C-10 as they had disk fronts standard.I have converted the front to disk from a 85 chev.The large bowl is in front of the master, small bowl closest to the booster.The large bowl has a 3/16s line and the small rear bowl has a 1/4 line.Dont the front disk take more fluid than the drum rears? This is making NO sense at all.HELP PLEASE. Thank you Chip
Old 12-26-2008, 07:51 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Chip, take a look at MP's site, tech support/configurations, find your master cylinder design and go from there.
http://www.mpbrakes.com/technical-su...igurations.cfm
Semper Fi
Old 12-27-2008, 09:35 AM
Thank you!!!!
I have finally got the answers to my questions----THANK YOU!!!!!!!!!!!!!!
Old 12-27-2008, 09:51 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
The stock original masters for C-10 were plumbed opposite compared to the C-20. That makes it confusing if you look at other trucks to see how GM did it.
Master cylinder brake line questions Stroker56 Suspension - Brakes - Steering 5 04-27-2006 08:40 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
New 12 bolt Rear/ questions. RObs71Nova Transmission - Rearend 1 12-27-2004 07:19 AM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
