1971 Camaro Diff ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2012, 11:29 PM
Predator4's Avatar
Last journal entry: Sleeping with the Camaro
1971 Camaro Diff ID
Hi all,
1971 Camaro base model. 10 bolt diff. I can not identify the diff. Has a number on the rear N then below 1285542. Passengers side stamp GO26 2 or G026 2. I have tried the internet but can not dial in on the right info.
What diff....what ratio? Does anyone have any ideas?
Old 12-13-2012, 08:11 AM
big gear head's Avatar
High Performance Rear Ends
'71 Camaro would have the 8.5 10 bolt if it hasn't been changed. I can't find a GO code for the Camaro.
Old 12-13-2012, 11:36 AM
Predator4's Avatar
Cheers ...The code seem a little unusual. Can not find any reference to the numbers
Old 12-13-2012, 12:50 PM
Bye Jerks
I know it's a pain, but pop the cover and count the teeth.
Only way to be sure of the ratio.
Old 12-13-2012, 10:33 PM
Predator4's Avatar
Thanks for the info. Sorry totaly new to diff stuff....so I count the teeth. What does this tell me?
Old 12-13-2012, 10:55 PM
Count the teeth on the ring gear and the pinion gear. Divide the number on the ring gear by the number on the pinion gear and that is your ratio. 41/11=3.73...
The Following User Says Thank You to big gear head For This Useful Post:
Predator4 (12-14-2012)
Old 12-14-2012, 02:01 PM
Predator4's Avatar
Thanks easy when you know how...Cheers
Old 12-16-2012, 10:34 AM
vinniekq2's Avatar
If you have trouble counting the pinion gear,look at the side of the ring gear.Most of them have the two numbers stamped on the edge like 41-11
Old 12-17-2012, 12:24 PM
Predator4's Avatar
Hi thanks. I have not pulled the cover yet... hope to take a look this weekend. Thanks again cheers
Old 12-18-2012, 04:36 PM
1971BB427's Avatar
Reach in and wipe the pinion gear clean enough to put a mark on one tooth with a white crayon. Then turn it and count from your mark. Same for the ring gear.
Old 12-18-2012, 11:40 PM
Predator4's Avatar
Cheers...All the help is great thanks
1971 Camaro Repalcement Firewall with AC ddailey Body - Exterior 2 02-22-2012 03:57 PM
How to lift the rear on a 1971 camaro? 1badLemans Suspension - Brakes - Steering 18 05-19-2011 06:57 PM
1971 SS 396 Camaro scottyo Engine 5 03-16-2010 11:45 AM
67 camaro diff fluid shclayto Transmission - Rearend 5 10-21-2005 04:29 AM
posi unit for 1971 Camaro todel1223 Transmission - Rearend 2 09-12-2005 11:22 AM
