1971 Camaro Diff Ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 12:04 AM
Predator4's Avatar
Last journal entry: Sleeping with the Camaro
Hi all... we have a few things together for our Camaro build but are not sure about the best gear ratio for the rear end. At the moment we have 2.73 gears. We think that these may be to tall for best performance with the cam. Would be happy to stick with these if they will work OK. We will use the car for cruising and take it to the strip a few times.
71 Camaro 350 SBC 350TH Trans. 3000 Stall
Comp Cams Magnum 280H Hydraulic Flat Tappet Camshaft
Lift: .490''
Duration: 280
RPM Range: 2000-6000
JEGS aluminium heads 64cc 170 intake runner 2.02 intake valves.
1.6:1 Roller rockers
Compression Approx 9.4:1
Performer RPM intake
750CFM Quick Fuel Slayer Carb
1-5/8 Headers
You recommendation would be greatly appreciated.
Cheers Wayne
Last edited by Predator4; 04-26-2013 at 12:08 AM. Reason: HTML taken over when pasteing
Old 04-26-2013, 06:14 AM
big gear head's Avatar
High Performance Rear Ends
3.42 is a very popular ratio for most street cars that will be raced a few times. I wouldn't go any farther than that without an overdrive transmission. You will also want to get an Eaton Posi if you have a standard differential right now, and a good installation kit. I'm guessing that you probably do a lot of shoping at Jeg's, but I do not recommend getting rear end parts from them or Summit. Go to Tom's Differentials or Randy's Ring & Pinion for rear end parts.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (04-26-2013), Predator4 (04-26-2013)
Old 04-26-2013, 06:42 AM
Last journal entry: Still running strong
With 3.42's an a TH 350 your rpms at 70 MPH will be 2900. I got tired of listening to my engine spining that fast. I changed to a 700r4 an kept the 3.42's now at 70 my rpm's are at 2100. Nice rpm drop.
The Following User Says Thank You to dogwater For This Useful Post:
Old 04-27-2013, 02:40 PM
Predator4's Avatar
Thanks for your help with this. We have the 2.73 gears at the moment will they work with the engine buid as described? We are on a very tight budget.
Old 04-27-2013, 04:41 PM
It will work, but performance will suck. Your cam won't like that gear much, and the converter is going to slip all the time.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (04-27-2013)
Old 04-27-2013, 08:11 PM
vinniekq2's Avatar
14 second bracket car
You can race the car as it is and just enjoy the drive. You will have a tonne of fun and after a season ,then decide if quicker is more fun.I can understand wanting to move to the 13.99 bracket and making everyone catch up.
Old 04-27-2013, 10:27 PM
Predator4's Avatar
Looks like I will need to spend a bit more on new gears to get everything to work well together.
Thanks again for the help.
Cheers Wayne
1971 Camaro Diff ID Predator4 Transmission - Rearend 10 12-18-2012 11:40 PM
Rebuilding a diff - what ratio to use with my T-350? Alpha67 Transmission - Rearend 9 04-21-2011 05:55 PM
1.7 to 1.8 ratio BBC rockers much diff...? Bumpstick Engine 6 04-28-2005 11:41 PM
Diff and gear box ratio :S boofis Transmission - Rearend 1 03-18-2005 11:39 PM
Comp. Ratio with diff. chambers redcamaro4spd Engine 11 07-10-2003 11:12 AM
