1971 chevy 350 power steering pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2006, 01:43 PM
colincamaro's Avatar
Wish I grew up in the 60's
Hey as explained in the title i have a 1971 chevy 350 and cannot figure out how to mount the power steering pump. The brackets are already on it and it mounts to the drivers side. There is just one bracket that i cannot figure out how to put on. It is twisted at an extreme angle and i cannot figure out how to mount to the car and pump. if anyone has any pictures or instructions that would be great, thanks for your help.
colin
Old 12-23-2006, 01:57 PM
malc's Avatar
Born To Be Mild
Is this similar ?
The mounting bracket for power steering is also used for the A/C.
Old 12-23-2006, 02:20 PM
yes its similar, but i don't have an a/c unit. my alternator is also on the same side as the pump. i moved it from the position you have it in the pic. http://yearone.com/serverfiles/fbshopmain2.asp?cat=8 this url has a picture of this piece that i cannot fit on the car. thanks again for your help
Old 12-23-2006, 02:24 PM
malc's Avatar
Born To Be Mild
I donīt see the part in question.
Old 12-23-2006, 02:29 PM
sorry its part number MRU86 on the same site.
Old 12-23-2006, 02:39 PM
malc's Avatar
Born To Be Mild
The description says it bolts to the head and slotted adjuster bracket.
Iīd assume itīs an alternative for the piece behind my steering pump reservoir.
I donīt have aircon now but it was always a puzzle to rebuild the setup after
doing anything to the front of my motor.
Old 12-25-2006, 02:51 PM
malc's Avatar
Born To Be Mild
Does this help ?
Old 12-26-2006, 12:43 PM
Yeah that helps a lot, thanks for the photos. Where did you get that piece though?? Its aftermarket right? Thanks again for the photos and responses.
Old 12-26-2006, 01:29 PM
poncho62's Avatar
Wiki Edits: 5
Are you running headers? That piece that malc showed is used when there is no exhaust manifold to bolt to anymore.....I made my own from a piece of flat steel.
Why did you move the alternator to the drivers side? That may be part of the problem.
Ontario Rodders
Old 12-26-2006, 03:38 PM
malc's Avatar
Born To Be Mild
colincamaro, I got the pic over at ChevyHiPerformance
but I cannot find the exact page in my computers history.
Old 12-27-2006, 01:14 AM
malc's Avatar
Born To Be Mild
Sorry not CHP but Popular Hot Rodding , this page
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
Power steering pump 1985 chevy k10 HELP! redneckrodder Suspension - Brakes - Steering 2 12-17-2004 05:11 PM
Power Steering 1955 Chevy willy6576 Introduce Yourself 1 10-27-2004 11:05 AM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
