1971 chevy truck fuel tank fill hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 01:39 PM
I am looking for some ideas on how to plug the hole in the cab where the stock fuel filler tube came through on my 71 Chevy truck. I'm going to run a fuel cell in the bed and run on e85 and use the space behind the seat for speakers. it has fresh paint so i do not want to weld and fill was thinking a large rubber plug. anyone know where to get one to fit or a better idea?
Old 01-30-2011, 01:50 PM
Underground's Avatar
Last journal entry: 54
Why don't you just cut the filler neck off of your tank and put it back in there. Then it will look like the factory tank it still there and not look like a rigged afterthought. I think a plug that big would look real tacky.
Old 01-30-2011, 03:11 PM
ogre's Avatar
the 'Duracell Project'
cut filler piece
weld in
Old 01-30-2011, 03:13 PM
ogre's Avatar
and then i read the rest of the story.... new paint
fugetaboutit
Old 01-30-2011, 04:31 PM
ya i could cut the neck off and leave it in there but the tank is in good condition. just thought i could find something like the original rubber grommet that the filler neck goes through without the hole in it that would seal it up.
Old 01-30-2011, 05:01 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
^^^^^^^^^^^^^^^x2
Old 01-30-2011, 06:17 PM
ericnova72's Avatar
More for Less Racer
Make a nice looking aluminum or stainless sheetmetal plate that fits the recessed lip of the hole and brush finish or polish the plate and then rivet it in place with a dozen rivets or so...gives that "aircraft skin" look. Don't be skimpy with the rivets, if you use just a few it looks cobbled, space them evenly around the edge at 3/4"-1" spacing.
Old 01-30-2011, 07:02 PM
thanks i like the aluminum plate idea
Old 01-30-2011, 07:49 PM
Nastynotch347's Avatar
I have a tank that leaks what do you want for yours?
Old 01-30-2011, 08:10 PM
i would take $75 for it
Old 01-31-2011, 06:38 AM
those old tanks are all over the place. if you dont want to cut yours, go get an old crappy one and cut the neck off, put the grommet on and epoxy a cap on so you don't accidently forget and soak the inside with fuel. No matter how nice you try and make a patch look, it still looks like a patch. It looks like an afterthought. It makes it look like the project wasn't thought through and you forgot to smooth the filler before you painted. Just my 2 cents
Old 01-31-2011, 04:55 PM
SSedan64's Avatar
Gas cap delete, Blazer Tank Swap
HOW TO: Poor man's no-weld gas cap delete>> http://www.67-72chevytrucks.com/vboa...d.php?t=250995
Blazer Tank Install on the CHEAP... $50>> http://www.67-72chevytrucks.com/vboa...d.php?t=234732
Rear fuel tank swap>> http://67-72chevytrucks.com/vboard/s...d.php?t=117123
ebfabman's gas tank filler patch>> http://67-72chevytrucks.com/vboard/s...ad.php?t=46657
Custom gas filler>> http://67-72chevytrucks.com/vboard/s...d.php?t=211579
blazer tank install... ON FLEETSIDE steel bed>> http://67-72chevytrucks.com/vboard/s...ad.php?t=82178
Old 01-31-2011, 05:10 PM
Wiki Edits: 27
big rubber plug
I've seen big rubber plugs fill the hole when truck cabs were used on custom build construction and military equipment,ski resorts equipment. I have no idea how to find one. some old artic snow cats used Ford cabs.
Old 02-23-2011, 05:46 PM
remanufactured transmissions
rebuilt enginesI recently just used craigslist to sale my tacoma because the transfer case grenaded the engine.
Chevy Truck Fuel tank relocating Pyro#102 General Rodding Tech 19 06-01-2014 08:04 AM
Hole in fuel tank, help! KNanthrup General Rodding Tech 14 07-11-2011 11:09 PM
C10 Fuel hole fill 70CHEVYSHORTY Body - Exterior 2 11-07-2009 01:08 PM
Need help on dual fuel tank wiring on 86 chevy truck shockers69 Electrical 2 12-26-2003 11:09 PM
fuel tank 65 chevy truck glghotrod General Rodding Tech 2 11-09-2003 12:35 AM
