1971 Ford 390, how do I convert it to HEI? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2011, 04:16 PM
hotrodcommuter's Avatar
anyone know what I can replace my points style distributor with? out of a late model xxxxx? I want to convert it to HEI
Old 04-24-2011, 05:00 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.performancedistributors.com/fordssdui.htm
Old 04-25-2011, 12:22 AM
Wiki Edits: 31
Ford didn't use the self contained HEI that GM did. They had the Duraspark from '75-'77 and Duraspark II in '-78-'83.. Ford used the 390 till '76 and Duraspark distributors were factory
Napa, carquest or any good parts store should be able to source you the correct distributor..
1976 F-150 w/ 4bbl 390 should get you $80 ish out the door for a distributor.. You will need the harness from a donor car ( any duraspark/ Duraspark II harness will work ) to use the factory ignition modual.. Otherwise you could wire a GM hei modual for a few bucks, or go MSD ignition for a few more. MSD even has an adapter connector to make it plug and play..
DUI distributors are supurb, but if your just looking for electronic ignition/ 40k+ volt capabilities, the Duraspark distributors will fit the bill
1971 400 Ford timing rebelbill1972 Engine 20 07-25-2010 08:28 PM
1971 ford wolf04 Engine 1 11-01-2009 05:40 PM
Big Block Ford ~ 429 ~1971 Help With Identification Please Rob Keller Engine 9 12-11-2007 03:42 AM
1971 ford torino 500 71TorinoGuy Engine 4 04-13-2007 05:20 AM
bbc in a 1971 Ford Galaxie Wildcat66 General Rodding Tech 10 03-16-2005 04:44 PM
