1971 ford ltd 460 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2011, 05:33 PM
1971 ford ltd 460
Hey guys I'm in the process of putting together a 460 with super cobra jet heads together for my 71. I know these boats came with a 429 which is the same block as the 460. My question is am I going to have to find frame mounts for this pig or does this engine have a mount which bolts directly to the frame. This is my first big block so I'm not sure what I'm in for.
Thanks for the help.
Old 06-03-2011, 12:49 PM
Wiki Edits: 27
mounts
all factory stuff for the 429 should bolt up. sometimes the accessorey pieces are different. ac p/s alternator etc are different from trucks , big cars, lincoln, merc to the 429 torino. the stuff for your body should be easy.
Old 06-03-2011, 01:43 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
That could be a serious understatement. Please describe in detail the heads you intend to use.
Old 06-03-2011, 06:45 PM
I have a set of c8ve ready for it, but I have a set of ford motorsport super cobra jet heads at the machine shop. Anyone know of a place to get the frame mounts for this pig? I also seem to be having issue's locating a set of headers that I wont have to custom build.
Old 06-03-2011, 10:21 PM
Wiki Edits: 27
hard ceats ?
Do the C8 heads have hardened valve seats. they also made a change in the rockers somewhere along that time
Old 06-04-2011, 04:21 AM
I have read that Hooker 6126's fit well but I have no personal experience with them in that body style.
Check with Dearborn Classics on the motor mounts. May be same as Torino.
Old 06-05-2011, 06:26 PM
the heads have the old style seats still...I dont want to dump a ton of money into the heads with the aluminum monsters getting worked on. The rockers look to be 1.7 ratio normal stud mount. Never thought of looking at dearborn I will have to check that out thanks
Old 06-05-2011, 11:55 PM
Wiki Edits: 31
Frame mounts are a thru bolt type that goes into the frame. I pulled the 460 from a '75 Lincoln and I don't seem to remember any real type of frame 'mount'. I think the there was a pad that the motor mount sat into, and I think it was part of the frame.. I know that the motor mounts cross with the LTD so that should all be the same, and the motor mounts are available from the parts store
1971 Ford 390, how do I convert it to HEI? hotrodcommuter Hotrodding Basics 2 04-25-2011 12:22 AM
1971 400 Ford timing rebelbill1972 Engine 20 07-25-2010 08:28 PM
1971 ford wolf04 Engine 1 11-01-2009 05:40 PM
1971 ford torino 500 71TorinoGuy Engine 4 04-13-2007 05:20 AM
bbc in a 1971 Ford Galaxie Wildcat66 General Rodding Tech 10 03-16-2005 04:44 PM
