1971 Galaxie 9" rear end three link questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2009, 08:42 PM
I just picked up 1971 Galaxie 9" rear end for my rod project . The housing has brackets for a three link set up (factory I assume).
I figure no sense reinventing the wheel, I would like use the factory brackets with new bars.
The question I have is can these bars be purchased or am I going to have to make them.
Old 10-05-2009, 08:04 AM
I would imagine finding a set would be NO PROBLEM ... but why ?
You know that your chassis will require some with a different length.
Might as well fabricate some the correct length.
Old 10-05-2009, 10:26 AM
I guess you are correct, might as well build to suit.
9" Versailles rear end? Daymo Transmission - Rearend 6 09-01-2009 07:49 AM
Ford 9" Rear End ID smokey626 Transmission - Rearend 6 03-16-2009 01:36 AM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Chevy rallys on a 9" rear end ja68 Hotrodding Basics 4 07-18-2008 03:48 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
