1971 LT1 heads: are they high performance - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2006, 07:50 PM
I got a set of 71' lt1 heads. I am puting them on a 350 with a TPI closed loop injection system. I need to know if I can get some hp out of these heads.
Old 10-04-2006, 12:23 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
certainly not high performance by today's standards. As inexpensive as they are, get yourself some 885 casting vortec heads. They can be found for $250 a pair used and they flow not only much more quantity, but much better quality air. They'll support up to about 350 hp as cast, much more in the hands of a good porter.
Old 10-04-2006, 10:24 AM
Those heads were rated at 370gross hp on the LT1s. They flow ok as cast. As stated above a set of vortecs will out flow them by a lot, they have better combustion chambers also. You can get some power out of the LTs with some port work but it might be more worth it to go with a set of vortecs.
Old 10-04-2006, 03:22 PM
stepside454's Avatar
sell the LT-1 heads to someone restoring an LT-1 Camaro or Vette, you should get a good price for the from someone doing a resto. John
LT1 Heads BCNU 64 nova Engine 5 09-28-2003 04:58 PM
lt1 heads ambrosemii Engine 5 07-11-2003 10:19 AM
high performance 283 steve Engine 2 06-22-2003 03:25 PM
LT1 Heads on Older Block? Hammar Engine 9 04-24-2003 10:23 AM
high performance parts for 5hp honda engine? atlantisjones Engine 1 05-19-2002 07:44 PM
