1971 Malibu gear swap questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2006, 10:22 AM
Hey, I have a 71 Chevelle malibu with the factory 10 bolt rearend with the factory gear set. The posi Unit was rebuilt. I want to go lower on the gears, but not so low that It's not driveable due to horrible gas millage. I'm using it as a street car, no track, but I want to get more power. What gear set would you recomend? and how difficult are the ring and pinion gears to install? do they need to have the back lash set in them? Are all the GM 10 Bolt rearends the same 8.5" ? any info would be greatly appreciated
Old 06-18-2006, 03:14 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
List your transmission, current gear ratio, tire size, and your main intended use of the car and we can further help you.
rear end gear swap Jared Engine 3 03-19-2003 08:46 PM
TH350 swap questions WS6tech Transmission - Rearend 13 11-26-2002 04:03 PM
dash swap monte ss into a malibu HOTWHEELSBOY28 Interior 4 10-13-2002 12:52 PM
AOD to 4r70w gear swap 5.0Towncar Transmission - Rearend 0 10-08-2002 02:17 PM
Gear swap question dion Transmission - Rearend 1 08-27-2002 08:26 AM
