Call West Coast Differentials in Sacto for information on your carrier.
1-800-510-0950 You can use the 8.5" axle from a later Nova if you want to upgrade to a stronger setup. There are a lot of these still under cars at Pick-n-Pull for pretty cheap. It is also easier to find parts for the 8.5. |
Sorry for being so dumb ONova, but do you mean that I can use the same case and upgrade to an 8.5 rear end? If that is true, would there be much advantage over an 8.2" rear end?
Dave |
That 10 bolt will eventually give up the farm, not from gear failure but from the spring perches rolling off the axle tubes. Do away with the original bolts that just go through the spring perch pad and find some U bolts that will go over the axle tubes through the spring perch pad. If you start drag racing that car and even with street tires it will eventually fail at the spring perches.
Vince |
A thousand dollars ... at the most ... should do the job ... with a little careful shopping ... Deuce ... |
Thanks for your replies everyone. So the perches twist off? Even with U-bolts? ...and the tubes, too? I guess that's why my friend builds his 9" setups with this massive brace running across the back.
I'll do some more boneyard crawling and see what I find. Dave |
Chances of finding a 9" rear in a boneyard that'll fit a Nova are slight. |
[QUOTE=onovakind67]You've got to put some pretty serious strain on the rear end to twist things up. QUOTE]
Not as much as you would think. I had a 70 Nova 307, 600 Holley, Tarantula intake, cyclone headers, Crower 280/rev kit, Muncie 4 speed. Spent every other weekend at Abilene Texas dragstrip when I was stationed there. I rolled the rear axle right off the spring perches. Probably producing about 300-350hp, enough to run a mid 13 second quarter. Vince |
Mid 13s in a '70 Nova sounds like you were making closer to 350 than 300, but still I'm surprised you came off the perches. Did the welds or the U-bolts break? I have heard about guys breaking axels and u-joints, but rolling off the perches is a new one to me. It must have been exciting! At least it happened at the line instead of at the end of your run!
Dave |
Didn't have u bolts at the time the welds on the perches broke. The Nova just had a plate that sandwiched the spring in between the spring perch with 4 bolts per side. After the perches came loose I found a 12 bolt and did away with the bolts and installed u bolts that went over the axle tube....problem solved.
Vince |
Super Sport car with a 396/375 Horsepower and a 4 speed. Twisted the tubes ... went to a Ford 9 inch ... Car got a 427 ... then a 454 ... eventually had to go to a 31 spline axle ... with Summers Brothers axles ...Then broke Muncie transmission cases ... Also went 10.65 in 1971 ... in the quarter ...No Bottle ... just horsepower ... 10 inch wide tires ... ( big for the time ... no 14X32's back then ) Lots of 57 to 59 Fords in the Junk yard around here ...
I broke the perches off my '69 Nova with a stock 230 & 3-speed stick. They were barely more than tack-welded on. I had a shop weld them all the way around, and also where the tubes press into the center casting. I also used U-bolts, 2 on each side.
A '72 Nova should have an 8.5" 10-bolt with monoleaf spring perches, except the SS versions, which have multileaf springs, and one U-bolt on each side. From '73-'79, all Novas use multileaf springs & single U-bolts, and most V-8 cars used 8.5" rears. All the forementioned will bolt into your car, although the 8.5" is slightly longer (axle centerine to U-joint), and will sometimes, not always, require a shorter driveshaft. |
| 66 nova rear end | robbysapien | Transmission - Rearend | 5 | 08-01-2007 07:48 PM |
| 77 Nova rear end compatibilty? | tms | Transmission - Rearend | 12 | 05-08-2006 05:13 PM |
| Looking for some opinions on my rear end. | NovaSS350 | Transmission - Rearend | 20 | 12-08-2004 01:07 AM |
| Nova rear end | sb72elcamino350 | Transmission - Rearend | 4 | 11-22-2003 03:34 AM |
| 70 nova rear end 355'swhat no.splines | oldnable | Transmission - Rearend | 5 | 07-18-2002 11:39 AM |
