1971 Nova spring perches? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2006, 10:00 AM
Hello Everyone,
With a great deal of help I've found that my 71 Nova rear end is an 8.5 10 bolt.
I'm trying to figure out what would be the best option for leaf springs? My rear end appears to have mono leaf spring perches, can multi leaf springs be used with these spring perches?
Thanks
Mac
Old 12-04-2006, 10:09 AM
Yes, you can use multi's on a mono perch. There are lots of opinions on how to do this, but I basically make it like a Mopar/Ford mount with the spring clamped metal to metal by u-bolts. I drill the upper channel to fit the centering bolt with a Bullet drill so I don't penetrate the housing, drill the shock plate to fit the new 1/2" u-bolts and torque it down. If your centering bolt sticks out too far you can use a short lowering block between the spring and mount or grind the bolt to fit.
Old 12-04-2006, 10:30 AM
Thank you very much for the prompt reply,(GREAT site).
Are kits available for this conversion i.e. spring pads, mounting hardware etc?
Thanks Mac
Old 12-04-2006, 01:28 PM
You don't need any pads, just springs and u-bolts. Most places that sell springs will also sell the u-bolts. If not, you can get u-bolts at most auto parts stores in a kit or as part of a lowering kit.
ID the differential in a 1971 Nova 1971 Nova Transmission - Rearend 7 11-30-2006 08:04 AM
1971 Nova Rear End Opinions bluesman123 Transmission - Rearend 13 08-25-2006 10:37 PM
narrow spring perches bosswillys Transmission - Rearend 4 04-09-2006 10:59 AM
1971 Nova SS. Just Livin Life Introduce Yourself 2 03-23-2006 01:11 PM
spring perches 71gtx Transmission - Rearend 9 12-13-2003 03:54 PM
