hello
i need to find a set off hinges for my trunk lid
impossible to find those parts , unless if i find a nova in a junk yard
does anyone know if the hinges from a 71 chevelle will work? or 71 camaro?
there is some available aftermarket billet aluminum but too expansive and don't look original
I will bet a crisp $10 bill that the hinges are straight and it's the body that is out of whack. But lets start with what EXACTLY is the problem? How is the lid fitting that suggests the hinges are bent?
Is it high in the back, low in the back, over to one side, high in the front up at the rear window, or is it too low there, what exactly is saying the hinges are bent?
I am 99% sure we can get this straightened out with the hinges. :thumbup:
Wait you still have the hinges? I'm sure you can straighten them out or fix whatevers wrong. Trunk hinges arent something i would imagine breaking on a car like a nova.
im in san francisco
i finaly find some....
there is this a huge big junk yard in the nevada , called desert valley
if you need rare parts its a good place to go
Vincent, you aren't listening, you VERY likely don't need hinges. But if you want to spend money and time and get some that is fine with us.
As a few of us have said, bending hinges on a car like that is VERY unlikely. But if they are a little tweeked, they can be VERY easily repaired right where they are.
What exactly is the problem with the fit of the trunk?
it would suck to deal with those tensioners AND figure out at the same time you have more adjusting to do with these new ones. As Martin mentioned and asked, let us know why you are getting new hinges and if you can show us some pics of the issues. He's trying to help you save time and money and with a little patience everyone on board will help you out as much as possible to walk you through this.
on one side the trunk is just a little highter , its a little too much on the right ,
and between the back window and trunk there a big gap ,the trunk dont fit properly
i bring the car at the garage , they did the machin frame stuff
and they told me i need to get some hinges , to get the final work done
Vincent, first off, I can't make this clear enough, I know you are just talking with some guys on a forum and not even face to face. You don't know who we are and you went to a shop, spoke face to face with guys who had a lot of wonderful equipment and they SHOULD know what they are talking about.
The cold hard fact is, it is a very real possibility they don't have a clue as to what is wrong. I work with guys every day, pros, guys with decades of experience who don't have a clue about stuff like this. They change parts and that is all they can do.
Yes the hinge may be bent, but it is often very easy to repair. If your lid is over to one side, that is childs play, just align it properly. If it needs a little help to push it over like the holes aren't big enough or something, fine it may need that. But unless the lid is over an inch I seriously doubt it is more than simply loosing up the CORRECT bolts and moving it over. Removing the striker so you can open and close the lid freely.
stay tuned cause in episode 43 I get a lot deeper on the subject and it's the best video I ever made.
As Martin said, let's see some detailed and up close pics of the issues and we can walk you thru it.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
