Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1971 Plymouth Roadrunner Seats
Old 10-31-2012, 01:52 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
And this is the finished product. The headrests were extremely difficult because they were heat sealed and molded to the headrest foam. They were also split open. I had to cover them with 1/4" sew foam and then make a pattern. I was hoping to be able to staple the covers to the headrests, but had to glue them on instead. Two headrests that took an entire day to finish. There was also a lot of spring repair that needed to be done. One broken spring on each of the front and rear seat bottoms, three springs that had worked loose over time, replacing the burlap over the seat springs with something more mouse resistant and more supportive of the seat foam, and tying the springs together with tie wires to make them act as a unit. I also had to dye the brown plastic pieces black, like the end covers of the front seat backs and the support tubes for the headrests.
ID:	68745   Click image for larger version
ID:	68746   Click image for larger version
