1972 to 1970 front end conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2007, 01:44 AM
Does anyone know if I need a kit, or if the grille, headlight basket and bumper from a 1970 A-body will mount up to the front of a 1972? I'm more partial to the quad headlight look and lack of corner signals.
thanks,
Josh
Old 09-23-2007, 06:42 AM
71velle's Avatar
conversion
it bolts on but you may need to make some minor adjustments and you'll need a 70 front bumper and 70 front fenders to get your blinkers as they are on the bumper and the lower sides of the fenders for 70, also if your doing that you may want to change to a 70 rear bumper as it is way different than a 72.
Old 09-23-2007, 08:24 AM
You'll also need a 70 core support.
Cheyenne to Silverado Front end ok4ayl Electrical 3 11-09-2008 09:51 AM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 08:03 PM
front end shake brainsboy Suspension - Brakes - Steering 3 02-14-2005 11:30 AM
raise the front end of the Chevelle tetzlaff Suspension - Brakes - Steering 3 09-19-2002 11:22 AM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 06:33 PM
