1972 454 4 bolt bored 0.100, what are the best set up for it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 02:42 PM
vcb vcb is offline
HELP get over 600 lb torque, with 454 0.100 storker
1972 454 4-bolt 0.100 cement filed up to the water holes, what are the best set up for it to run it in 92 octane and get over 600 lb torque.
So far i came up with this.
Balanced Stroker kit
4.350 Forged pistons (flat, domed or disk are better?)
4.250 in. crank
6.385 in. rods
Cams Kit Hydraulic Roller 242/248 duration at .050-inch and lift of .566-inch.
Aluminum Heads, oval open chamber 320cc intake ports, stainless 2.25-inch intake and 1.88-inch exhaust valves. 119cc chamber volume.
(what about the L88 heads?)
Holley 950 HP carb, Performer RPM intake
thanks
v
Old 03-29-2010, 12:56 AM
Bad Influence Racing's Avatar
Engine Builder/Head Porter
I would sonic check the block to make sure it will handle that bore without needing a partial fill. Otherwise a 4.310" is alot more street friendly and won't need fill. You won't fit a 4.500" stroke in a factory stad deck block. Biggest is a 4.375" which doesn't make for a good street combination. I do alot of the 496 combinations or 498 at a 4.320" bore with no issues and make killer power. The camshaft will depend on many factors, as do the heads, intake, carb and rest of the apllication. I would rather no budget and how fast you plan on going and what the application is for me to get you into the right combination. I have alot of them for a pump fuel deal. What car is going in? weight? gear? converter? tire? Fill me in.
Kris
Old 03-29-2010, 10:22 AM
vcb vcb is offline
Hi,
I just updated the info for my project.
Would love to get some good help.
thanks
v
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
6 lug chev bolt pattern, what else will it fit? tiresmoke55 General Rodding Tech 2 01-23-2006 05:56 AM
Where to get a set of Unilug washers and nuts to fit? Dubz Hotrodding Basics 1 07-06-2004 07:33 AM
What will this 12 bolt rearend from 71Monte Carlo fit? shockers69 Transmission - Rearend 4 04-23-2004 08:54 PM
Will Intake 454 fit on 400 Firebird Auto-Part Engine 6 11-05-2003 09:49 PM
