1972 Camaro Factory air retrofit - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2008, 06:12 PM
Zanzahl's Avatar
Camaro RS 1972
I hope this is the proper forum:
I am attempting to put factory A/c in a 1972 NON factory A/C vehicle.
The engine is out and the inner fender is tucked away.
Plan is to cover the heater opening with 1/16th steel.
enlarge firewall to accomodate the Factory A/C.
The factory A/C is off a 1973 Formula Firebird and has been in storage a long long time .
The car is wired for the Z28 sport package with A/C so ALL wiring is present.
I have ALL the pieces fro the A/C from the control switch out to the evaporator and A/C compressor. I obtained a rebuilt/reconditioned A6 compressor.
The question is - What A/C Evaporator will be a good fit so as to upgrade the A/C and keep it original in appearance. The Evaporator has been exposed to air and is not trust worthy enought to use.
Any assistance is appreciated. Even if it is pitfall avoidance etc...
Thank you in advance.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
using a respirator robs ss Body - Exterior 10 08-23-2007 06:31 PM
Camaro seats retrofit??? dpjmw Interior 2 01-10-2005 05:57 PM
camaro air intake prob chevcamz28newbie Engine 3 07-15-2003 01:30 PM
factory gears 89 camaro shane7643701 Transmission - Rearend 2 05-21-2003 11:41 AM
